cgal-discuss - Re: [cgal-discuss] Re: question about running cgal example in qt-creator.
  • To:
  • Subject: Re: [cgal-discuss] Re: question about running cgal example in qt-creator.
  • Date: Wed, 5 Jun 2013 06:38:23 +0800
Hi, Laurent,
      I have another question. Yes, because of the working directory problem, so the program read a unexist file and  I got the !empty() exception (The AABB_tree is empty). The working directory of qt-creator launching the program is
/home/huayiwei/work/program/meshGenerator/example/Regular_triangulation/Mesh_3/build/
But the data is in
/home/huayiwei/work/program/meshGenerator/example/Regular_triangulation/Mesh_3/data/
When the program use following code to input domain data:
 // Create domain
  Mesh_domain domain("data/fandisk.off");
it actually try to read the following file:
/home/huayiwei/work/program/meshGenerator/example/Regular_triangulation/Mesh_3/build/data/fandisk.off
which doesn't exist.
My question:  when the program try to read a unexist file, it should directly 'complain' about it, isn't it?
Best
Huayi
2013/6/4 魏华祎 <>
Hi, Laurent,
     Thanks for your reply. Yes, you are right. It is the working drectory problem.
Best
Huayi
2013/6/3 Laurent Rineau (CGAL/GeometryFactory) <>
Le lundi 03 juin 2013 20:21:31 é­ å Žç¥Ž a écrit :
> Dear all
>       I use QT Creator 2.4.1 as my IDE, and my system is Ubuntu 12.04 amd
> 64. My CGAL version is 4.2.  When I  run the example of
> CGAL/exmaple/Mesh_3/mesh_polyhedral_domain_with_features.cpp in QT Creator,
> I meet such a problem:
> Starting
> _3/build/mesh_polyhedral_domain_with_features...
> terminate called after throwing an instance of
> 'CGAL::Precondition_exception'
> what(): CGAL ERROR: precondition violation!
> Expr: !empty()
> File: /usr/local/include/CGAL/AABB_tree.h
> Line: 152
> The program has unexpectedly finished.
> But I can run the compiled program directly in my bash shell and get the
> result mesh.  Did anyone ever meet the same problem? Please help, thanks a
> lot.
The difference must be the working directory where the program is launched. It
must be the one of sources, in your case:
Laurent Rineau, PhD
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
Release Manager of the CGAL Project       http://www.cgal.org/
