cgal-discuss - Re: [cgal-discuss] Re: Divide by Zero in AABB tree
  • To:
  • Subject: Re: [cgal-discuss] Re: Divide by Zero in AABB tree
  • Date: Fri, 07 Jun 2013 07:15:49 +0200
What you sent confirm my first guess, you have a degenerate triangle.
It is the only way you can have a plane with (0,0,0) normal vector.
Could you make a check on the polyhedron before building the AABB-tree?
for (Polyhedron::Facet_iterator fit=polyhedron.facets_begin();
fit!=polyhedron.facets_end();
++fit)
if ( CGAL::orientation(
fit->halfedge()->vertex()->point(),
fit->halfedge()->next()->vertex()->point(),
fit->halfedge()->opposite()->vertex()->point() )
== CGAL::COLLINEAR )
{ std::cout << "degenerate triangle\n"; }
Sebastien.
On 06/06/2013 10:35 PM, schrodingersnewcat wrote:
The four stacks are from four process running independently on four different
nodes. They have no shared memory. They don't even pass messages at this
point in the program.
Here is a backtrace from a run where I have removed MPI. single.trace
<http://cgal-discuss.949826.n4.nabble.com/file/n4657660/single.trace>
Sorry I didn't get back sooner, I didn't see your response until today.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Divide-by-Zero-in-AABB-tree-tp4657026p4657660.html
