- To:
- Subject: Re: [cgal-discuss] Re: Divide by Zero in AABB tree
- Date: Mon, 10 Jun 2013 07:16:37 +0200
On 06/10/2013 01:04 AM, schrodingersnewcat wrote:
Okay, I've done that and it does indeed come back telling me there areStrange...
degenerate triangles.
First a note. I had to use this snippet instead of what you posted as
CGAL::orientation was giving me an error.
Try calling join_facet on the 0-length edges:
for (Polyhedron::Facet_iterator fit=polyhedron.facets_begin();
fit!=polyhedron.facets_end();
++fit)
if ( CGAL::collinear(
fit->halfedge()->vertex()->point(),
fit->halfedge()->next()->vertex()->point(),
fit->halfedge()->opposite()->vertex()->point() ) )
std::cout<< "degenerate triangle\n";
So, now my question is how do I repair a polyhedron that has developed this
pathology and how does it occur in the first place?
As I said before I'm using a kernel with an exact number type. In fact it
is interchangeable with CGAL::Exact_predicates_exact_constructions_kernel.
I just wanted to specify the number and kernel type manually.
The polyhedrons I'm using are the result of boolean operations using Nef
polyhedrons. Each is converted from a Nef polyhedron a few steps before I
create the AABB trees.
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron_ref/Class_Polyhedron_3.html#Function_Halfedge_handle_join_facet6_Halfedge_handle_h9;
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Divide-by-Zero-in-AABB-tree-tp4657026p4657665.html
- [cgal-discuss] Re: Divide by Zero in AABB tree, schrodingersnewcat, 06/06/2013
- Re: [cgal-discuss] Re: Divide by Zero in AABB tree, Sebastien Loriot (GeometryFactory), 06/07/2013
- [cgal-discuss] Re: Divide by Zero in AABB tree, schrodingersnewcat, 06/10/2013
- Re: [cgal-discuss] Re: Divide by Zero in AABB tree, hank choi, 06/10/2013
- Re: [cgal-discuss] Re: Divide by Zero in AABB tree, Sebastien Loriot (GeometryFactory), 06/10/2013
- [cgal-discuss] Re: Divide by Zero in AABB tree, schrodingersnewcat, 06/28/2013
