- To:
- Subject: Re: [cgal-discuss] Polyhedron plane to nef polyhedron and back again
- Date: Mon, 10 Jun 2013 07:30:13 +0200
On 06/07/2013 02:56 PM, pwr00 wrote:
Hi!Do you mean a bounded part of a plane?
Sorry about the repost. Seems like I have some issues with becoming allowed
to post to the mailing list. I have been trying to find a answer to this
question for a couple of weeks now and feel a bit lost.
The basic problem is like this:
1. I create a Polyhedron3 that is a plane.
2. Convert the Polyhedron3 to a NefPolyhedron in order to make booleanIf you want to work with infinite planes, it is the way to go.
operations on it.
3. I convert the NefPolyhedron back to Polyhedron3.
My problem is that step3 triggers an assert because the shape is not simple.
What options do I have in order to make boolean operations on a plane? Could
someone point me in the right direction?
- Can I temporarly close the shape somehow?
- I've read in the manuals that it should be possible to define a plane that
spans the entire space.
29.3 Infimaximal Box in
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Nef_3/Chapter_main.html
Is this somehting that can solve my issues?
Note that if the result is not simple you will not be able to
export it to Polyhedron_3 anyway. You will need to proceed for each shell.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Polyhedron-plane-to-nef-polyhedron-and-back-again-tp4657664.html
- [cgal-discuss] Polyhedron plane to nef polyhedron and back again, pwr00, 06/07/2013
- Re: [cgal-discuss] Polyhedron plane to nef polyhedron and back again, Sebastien Loriot (GeometryFactory), 06/10/2013
- [cgal-discuss] Re: Polyhedron plane to nef polyhedron and back again, pwr00, 06/15/2013
