- To:
- Subject: [cgal-discuss] Circulator order and Voronoi Cell from Vertex_handle
- Date: Thu, 20 Jun 2013 11:24:37 -0500
Hello,
I am getting the voronoi cell (a Polygon_2) from a Vertex_handle, on a constrained Delaunay Triangulation.
Getting the points of the Polygon is easy when all the faces aren't constrained (blind), because you only use a Circulator to get all the faces incident to the Vertex_handle and get their circumcenters.
When there is Constrained it becomes a pain, because you need to calculate the points of that polygon that intersect with the constraint.
I got this points by using the middle point of the current Vertex_handle comparing it with the vertex_handle on the current face of the circulator, and it works, I get the points.
I have a problem understanding which is the order of a circulator, is it cw? ccw?, because to get a Polygon_2 I have to get the points in order, if not it becomes a totally different Polygon.
Can someone help me with this? first let me understand which is the order of a Circulator (for 2D meshes) and maybe if there is an easier way to get the voronoi cell from a Vertex_handle for Constrained Delaunay Triangulations.
Thank you.
Raul O. Gallegos Hidalgo
- [cgal-discuss] Circulator order and Voronoi Cell from Vertex_handle, Raul Gallegos, 06/20/2013
- Re: [cgal-discuss] Circulator order and Voronoi Cell from Vertex_handle, Sebastien Loriot (GeometryFactory), 06/21/2013
- Re: [cgal-discuss] Circulator order and Voronoi Cell from Vertex_handle, Monique Teillaud, 06/25/2013
