cgal-discuss - Re: [cgal-discuss] Circulator order and Voronoi Cell from Vertex_handle
  • To:
  • Subject: Re: [cgal-discuss] Circulator order and Voronoi Cell from Vertex_handle
  • Date: Fri, 21 Jun 2013 07:45:31 +0200
It is not documented but if you are at the infinite vertex it will be
cw, and ccw otherwise.
Sebastien.
On 06/20/2013 06:24 PM, Raul Gallegos wrote:
Hello,
I am getting the voronoi cell (a Polygon_2) from a Vertex_handle, on a
constrained Delaunay Triangulation.
Getting the points of the Polygon is easy when all the faces aren't
constrained (blind), because you only use a Circulator to get all the
faces incident to the Vertex_handle and get their circumcenters.
When there is Constrained it becomes a pain, because you need to
calculate the points of that polygon that intersect with the constraint.
I got this points by using the middle point of the current Vertex_handle
comparing it with the vertex_handle on the current face of the
circulator, and it works, I get the points.
I have a problem understanding which is the order of a circulator, is it
cw? ccw?, because to get a Polygon_2 I have to get the points in order,
if not it becomes a totally different Polygon.
Can someone help me with this? first let me understand which is the
order of a Circulator (for 2D meshes) and maybe if there is an easier
way to get the voronoi cell from a Vertex_handle for Constrained
Delaunay Triangulations.
Thank you.
Raul O. Gallegos Hidalgo
