- To:
- Subject: [cgal-discuss] How to check if a Vertex is on a constraint
- Date: Thu, 20 Jun 2013 16:17:43 -0500
How can I check (on O(1) if possible) if a vertex is on a constraint (Edge or two vertices) ?
I wouldn't want to iterate every edge on the CDT and check the vertices inside.
Regards,
Raul O. Gallegos Hidalgo
- [cgal-discuss] How to check if a Vertex is on a constraint, Raul Gallegos, 06/20/2013
- Re: [cgal-discuss] How to check if a Vertex is on a constraint, Sebastien Loriot (GeometryFactory), 06/21/2013
