cgal-discuss - [cgal-discuss] Any bug in Kinetic_Delaunay_triangulation_3 (CGAL4.2)?
  • To:
  • Subject: [cgal-discuss] Any bug in Kinetic_Delaunay_triangulation_3 (CGAL4.2)?
  • Date: Thu, 27 Jun 2013 17:08:12 -0700 (PDT)
Dear all,
I am trying to build the latest 4.2 by VS2010+boost_1.52 in Windows 7 64bit
system. I selected 'with examples' and 'with demos' in CMake setting and
then build all projects. Now all projects passed except the one
'Kinetic_Delaunay_triangulation_3', the errors are as follows. Could anyone
help me to take a look at it?
Thanks
Zhanghong Tang
1>------ Build started: Project: ZERO_CHECK, Configuration: Release x64
2>------ Skipped Build: Project: install_FindCGAL, Configuration: Release
x64 ------
2>Project not selected to build for this solution configuration
3>------ Build started: Project: ALL_BUILD, Configuration: Release x64
3> Build all projects
4>------ Build started: Project: Kinetic_Delaunay_triangulation_3,
Configuration: Release x64 ------
4> Kinetic_Delaunay_triangulation_3.cpp
5>------ Skipped Build: Project: INSTALL, Configuration: Release x64 ------
5>Project not selected to build for this solution configuration
6>------ Skipped Build: Project: demos, Configuration: Release x64 ------
6>Project not selected to build for this solution configuration
4>E:/Users/tang/tang/mesh/CGAL/CGAL4.2/64bit_MT/examples/Kinetic_data_structures/../../include\CGAL/Kinetic/internal/Delaunay_triangulation_base_3.h(877):
error C2665:
'CGAL::Kinetic::internal::Delaunay_3_edge_flip_event<KD,RS>::Delaunay_3_edge_flip_event'
: none of the 2 overloads could convert all the argument types
4> with
4> [
4>
KD=CGAL::Kinetic::Delaunay_triangulation_3<Traits,CGAL::Kinetic::Delaunay_triangulation_event_log_visitor_3>,
4> RS=CGAL::Kinetic::Exact_simulation_traits::Root_stack
4> ]
4>
E:/Users/tang/tang/mesh/CGAL/CGAL4.2/64bit_MT/examples/Kinetic_data_structures/../../include\CGAL/Kinetic/internal/Delaunay_triangulation_base_3.h(91):
could be
'CGAL::Kinetic::internal::Delaunay_3_edge_flip_event<KD,RS>::Delaunay_3_edge_flip_event(const
RS &,const CGAL::Triple<T1,T2,T3> &,KD *)'
4> with
4> [
4>
4> RS=CGAL::Kinetic::Exact_simulation_traits::Root_stack,
4>
T1=CGAL::internal::CC_iterator<CGAL::Compact_container&lt;CGAL::Kinetic::Delaunay_triangulation_cell_base_3&lt;Traits,CGAL::Triangulation_cell_base_3&lt;CGAL::Kinetic::Exact_simulation_traits::Instantaneous_kernel,CGAL::Triangulation_ds_cell_base_3&lt;CGAL::Triangulation_data_structure_3&lt;CGAL::Triangulation_vertex_base_3&lt;CGAL::Kinetic::Exact_simulation_traits::Instantaneous_kernel>,CGAL::Kinetic::Delaunay_triangulation_cell_base_3<Traits>>>>>>,false>,
4> T2=int,
4> T3=int
4> ]
4> while trying to match the argument list
'(CGAL::Kinetic::internal::Certificate<Function_kernel_t>, const
CGAL::Triple<T1,T2,T3>,
CGAL::Kinetic::Delaunay_triangulation_3<TraitsT,Visitor> *)'
4> with
4> [
4>
Function_kernel_t=CGAL::Kinetic::Exact_simulation_traits::Simulator_function_kernel
4> ]
4> and
4> [
4>
4> T2=int,
4> T3=int
4> ]
4> and
4> [
4> TraitsT=Traits,
4>
Visitor=CGAL::Kinetic::Delaunay_triangulation_event_log_visitor_3
4> ]
4>
E:/Users/tang/tang/mesh/CGAL/CGAL4.2/64bit_MT/examples/Kinetic_data_structures/../../include\CGAL/Kinetic/internal/Delaunay_triangulation_base_3.h(850)
: while compiling class template member function 'void
CGAL::Kinetic::internal::Delaunay_triangulation_base_3<TraitsT,Visitor>::make_certificate(const
CGAL::Triple<T1,T2,T3> &,const
CGAL::POLYNOMIAL::internal::Simple_interval_root<Traits> &)'
4> with
4> [
4>
TraitsT=CGAL::Kinetic::Delaunay_triangulation_3<Traits,CGAL::Kinetic::Delaunay_triangulation_event_log_visitor_3>::Base_traits,
4>
Visitor=CGAL::Kinetic::Delaunay_triangulation_event_log_visitor_3,
4>
4> T2=int,
4> T3=int,
4>
Traits=CGAL::POLYNOMIAL::Sturm_root_stack_traits<CGAL::Kinetic::Exact_simulation_traits::Function>
4> ]
4>
E:/Users/tang/tang/mesh/CGAL/CGAL4.2/64bit_MT/examples/Kinetic_data_structures/../../include\CGAL/Kinetic/Delaunay_triangulation_3.h(196)
: see reference to class template instantiation
'CGAL::Kinetic::internal::Delaunay_triangulation_base_3<TraitsT,Visitor>'
being compiled
4> with
4> [
4>
4>
4> ]
4>
..\..\..\examples\Kinetic_data_structures\Kinetic_Delaunay_triangulation_3.cpp(13)
'CGAL::Kinetic::Delaunay_triangulation_3<TraitsT,Visitor>' being compiled
4> with
4> [
4> TraitsT=Traits,
4>
4> ]
7>------ Skipped Build: Project: examples, Configuration: Release x64 ------
7>Project not selected to build for this solution configuration
========== Build: 2 succeeded, 1 failed, 505 up-to-date, 4 skipped
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Any-bug-in-Kinetic-Delaunay-triangulation-3-CGAL4-2-tp4657721.html
