- To:
- Subject: Re: [cgal-discuss] Re: Triangulation on a sphere using CGAL.
- Date: Sat, 29 Jun 2013 14:39:27 +0200
Le 28/06/13 20:11, Michael Kalygin a écrit :
Alessandro, ah, I see.
To get a spherical triangle using triangulation's triangle you can build
geodesic lines:
http://en.wikipedia.org/wiki/Geodesic
You can put one dummy point in the center of the sphere and then build
3D triangulation of your set of points (with this dummy point). I'm
assuming that all your points belong to the sphere except the dummy
point. This will give you a polyhedron.
indeed
And then for each edge of the
polyhedron you can build a geodesic line. Hope this will help you.
to do this you can just construct a Circular_arc_3 from its two endpoints
See CGAL chapter 3D Spherical Geometry Kernel
best
Monique Teillaud
http://www.inria.fr/sophia/members/Monique.Teillaud/
INRIA Sophia Antipolis - Méditerranée
Institut National de Recherche en Informatique et Automatique
On Fri, Jun 28, 2013 at 8:33 PM, isscandar [via cgal-discuss] <[hidden
email] </user/SendEmail.jtp?type=node&node=4657731&i=0>> wrote:
Michael Kalygin wrote
Hi, isscandar, I understand that CGAL has a huge manual. I
started from
these sections. If you read them, you will understand how to
work with
triangulation. Take a look at examples too.
http://www.cgal.org/Manual/3.2/doc_html/cgal_manual/Triangulation_3/Chapter_main.html
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/TriangulationDS_3_ref/Concept_TriangulationDataStructure_3.html
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3_ref/Class_Triangulation_3.html
Hello Michael,
thank you very much for your help!
I have read some of the manual but I am still confused: quoting from
the manual /The class Triangulation_3 represents a 3-dimensional
tetrahedralization of points./ but I think I do not need
tetrahedrons in the space because I think I need spherical triangle
(http://mathworld.wolfram.com/SphericalTriangle.html), it is not
clear to me whether I can get the spherical triangle from the
tetrahedrons. What am I missing?
Alessandro
If you reply to this email, your message will be added to the
discussion below:
http://cgal-discuss.949826.n4.nabble.com/Triangulation-on-a-sphere-using-CGAL-tp4656139p4657730.html
To unsubscribe from Triangulation on a sphere using CGAL., click here.
NAML
<http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
Best regards,
Michael Kalygin.
View this message in context: Re: Triangulation on a sphere using CGAL.
<http://cgal-discuss.949826.n4.nabble.com/Triangulation-on-a-sphere-using-CGAL-tp4656139p4657731.html>
Sent from the cgal-discuss mailing list archive
<http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
- [cgal-discuss] Re: Triangulation on a sphere using CGAL., isscandar, 06/20/2013
- Re: [cgal-discuss] Re: Triangulation on a sphere using CGAL., Monique Teillaud, 06/25/2013
- [cgal-discuss] Re: Triangulation on a sphere using CGAL., Michael Kalygin, 06/25/2013
- [cgal-discuss] Re: Triangulation on a sphere using CGAL., isscandar, 06/27/2013
- Re: [cgal-discuss] Re: Triangulation on a sphere using CGAL., Monique Teillaud, 06/28/2013
- [cgal-discuss] Re: Triangulation on a sphere using CGAL., Michael Kalygin, 06/28/2013
- [cgal-discuss] Re: Triangulation on a sphere using CGAL., isscandar, 06/28/2013
- Re: [cgal-discuss] Re: Triangulation on a sphere using CGAL., Monique Teillaud, 06/29/2013
- <Possible follow-up(s)>
