- To: "" <>
- Subject: [cgal-discuss] having trouble buildling Mesh3 example
- Date: Thu, 4 Jul 2013 19:38:08 +0000
- Accept-language: en-US
Dear CGAL users,
I would like to play with the 3D Mesh generation example mesh_polyhedral_domain_with_features.cpp ,
however I'm finding that the build seems to be successful with most example directories, but is not successful in the Mesh_3 directory.
audette@msvel608:~/projects/CGAL-4.1Build/examples$ ls Mesh_3
CMakeFiles cmake_install.cmake Makefile
audette@msvel608:~/projects/CGAL-4.1Build/examples$ ls Mesh_2
CMakeFiles cmake_install.cmake conforming Makefile mesh_class mesh_global mesh_with_seeds
audette@msvel608:~/projects/CGAL-4.1Build/examples$ ls Polyhedron
CMakeFiles polyhedron_prog_normals polyhedron_prog_traits
cmake_install.cmake polyhedron_prog_off polyhedron_prog_vector
Makefile polyhedron_prog_planes polyhedron_prog_vertex_color
polyhedron_prog_color polyhedron_prog_simple polyhedron_prog_vertex_normal
polyhedron_prog_cube polyhedron_prog_subdiv polyhedron_self_intersection
polyhedron_prog_cut_cube polyhedron_prog_subdiv_with_boundary
polyhedron_prog_incr_builder polyhedron_prog_tetra
When I go into Mesh_3 and try a make from within, nothing seems to happen.
Can anyone suggest a fix?
Thanks for your kind support.
Best wishes,
Michel
Michel Audette, Ph.D.
Assistant Professor,
Department of Modeling, Simulation and Visualization Engineering,
Old Dominion University,
Norfolk, VA.
- [cgal-discuss] having trouble buildling Mesh3 example, Audette, Michel A., 07/04/2013
