cgal-discuss - [cgal-discuss] RE: having trouble buildling Mesh3 example - looks like a Boost CMake problem; how to fix?
  • To: "" <>
  • Subject: [cgal-discuss] RE: having trouble buildling Mesh3 example - looks like a Boost CMake problem; how to fix?
  • Date: Thu, 4 Jul 2013 19:58:14 +0000
  • Accept-language: en-US
Hi again,
I think that the Mesh3 CMake process is not acknowledging the existence of Boost successfully...
if ( CGAL_FOUND )
  include( ${CGAL_USE_FILE} )
  find_package(Boost)
  if ( Boost_FOUND AND Boost_VERSION GREATER 103400 )
    include( CGAL_CreateSingleSourceCGALProgram )
    # Compilable examples
    create_single_source_cgal_program( "mesh_implicit_sphere.cpp" )
    create_single_source_cgal_program( "mesh_implicit_sphere_variable_size.cpp" )
    create_single_source_cgal_program( "mesh_two_implicit_spheres_with_balls.cpp" )
(etc...)
My ccmake looks as follows... I have not been successful getting cmake to accept my BOOST_DIR properly, even though I went out of my way to get the Cmake-based Boost source tree and build it in the usual CMake fashion with a separate build directory.
Boost_DIR                        Boost_DIR-NOTFOUND
If there is a trick to get Boost_DIR to be set properly, please let me know...
Cheers,
Michel
Michel Audette, Ph.D.
Assistant Professor,
Department of Modeling, Simulation and Visualization Engineering,
Old Dominion University,
Norfolk, VA.
Sent: Thursday, July 04, 2013 3:38 PM
To:
Subject: [cgal-discuss] having trouble buildling Mesh3 example
Dear CGAL users,
I would like to play with the 3D Mesh generation example mesh_polyhedral_domain_with_features.cpp ,
however I'm finding that the build seems to be successful with most example directories, but is not successful in the Mesh_3 directory.
audette@msvel608:~/projects/CGAL-4.1Build/examples$ ls Mesh_3
CMakeFiles  cmake_install.cmake  Makefile
audette@msvel608:~/projects/CGAL-4.1Build/examples$ ls Mesh_2
CMakeFiles  cmake_install.cmake  conforming  Makefile  mesh_class  mesh_global  mesh_with_seeds
audette@msvel608:~/projects/CGAL-4.1Build/examples$ ls Polyhedron
CMakeFiles                    polyhedron_prog_normals               polyhedron_prog_traits
cmake_install.cmake           polyhedron_prog_off                   polyhedron_prog_vector
Makefile                      polyhedron_prog_planes                polyhedron_prog_vertex_color
polyhedron_prog_color         polyhedron_prog_simple                polyhedron_prog_vertex_normal
polyhedron_prog_cube          polyhedron_prog_subdiv                polyhedron_self_intersection
polyhedron_prog_cut_cube      polyhedron_prog_subdiv_with_boundary
polyhedron_prog_incr_builder  polyhedron_prog_tetra
When I go into Mesh_3 and try a make from within, nothing seems to happen.
Can anyone suggest a fix?
Thanks for your kind support.
Best wishes,
Michel
Norfolk, VA.
