- To:
- Subject: [cgal-discuss] Mesh cutting
- Date: Wed, 17 Jul 2013 10:01:55 +0200
- Organization: Von Karman Institute
Hello,
I would like to ask if CGAL slice elements in triangulation. Suppose my
input
is a line on a triangulated surface (given as a sequence of vertex pairs
indicating which mesh edges the line should cut, for example), I would like
to
split the triangles that the line passes through, eventually introducing new
triangles.
Thank you very much,
Martin Vymazal
- [cgal-discuss] Mesh cutting, Martin Vymazal, 07/17/2013
