cgal-discuss - Re: RE: [cgal-discuss] Volume mesh from 3D image
  • To:
  • Subject: Re: RE: [cgal-discuss] Volume mesh from 3D image
  • Date: Tue, 16 Jul 2013 16:22:10 +0200
Le mardi 16 juillet 2013 13:10:04
a écrit :
> Hi Laurent,
> Thanks for the help, I tried to reduce the size but still there are some
> disturbances over the surface (shown in the figure),
> Is it possible to use Octree based image instead of structured one? In this
> way I can reduce the image pixel size and
> concentrate it over the skin surface.
Can you tell us which software you use to produce that result (using CGAL),
or
what piece of code? And which parameters. I am surprise by the result.
Can you send the image to be, privately, so that I can try to reproduce your
bad results?
Laurent Rineau, PhD
