Re: [cgal-discuss] would like to understand how the facet and cell size objectives, and node insertion, work in Mesh_3
- To:
- Subject: Re: [cgal-discuss] would like to understand how the facet and cell size objectives, and node insertion, work in Mesh_3
- Date: Tue, 23 Jul 2013 11:08:09 +0200
edge_size bounds the size of edge which are part of 1 dimensional sharp feature approximation fecet_size bounds the radius of the surface Delaunay sphere of surface facet ( surface facets have by definition an empty circumsphere centered on the surface) cell_size bounds the circumradius of any tet in the mesh The Mesh_3 package of CGAL is based on Delaunay refinement and therefore can't guarantee to preserve the discretization of the input surface even if this surface mesh satisfies the meshing criteria. Indeed, input surface meshes might not have the Delaunay property. On one hand, this is a drawback of our meshing algorithm. On the other hand, since Mesh_3 is able to provide in a single meshing process multi-component domain mesh, respecting all boundaries and subdividing surface patches, there is generally no more need to preserve the input surface meshes. Simply think that the work performed to generate these input surface meshes is performed at the same time by CGAL meshing packahge Le 22/07/13 19:52, Audette, Michel A. a
écrit :
Dear CGAL users,
I would like to use Mesh_3 to produce a tetrahedral mesh with controlled resolution. The example in the website where the mesh resolution is controlled is the following... Mesh_criteria criteria(edge_size = 0.025, facet_angle = 25, facet_size = 0.05, facet_distance = 0.005, cell_radius_edge_ratio = 3, cell_size = 0.05); Please help me interpret
these thresholds. I would think that for a triangle, or
facet, whose area is related to edge size, whose objective
is s (s=0.025 here) it would be given by s^2*sqrt(3)/4,
and that the volume of a tetrahedron of edge size s would
be given by sqrt(2)/12 *s^3, and yet, in this example,
facet and cell sizes appear to be 2*s. Also, could someone
also explain the facet_distance concept to me: is there an
intuitive relationship with edge size?
I also found that even when I choose this way of invoking make_mesh_3, i.e.: providing it with a surface mesh input which contrains the volumetric meshing, C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria); for some reason, the volumetric meshing remeshes the surface mesh as well, thereby introducing other points that produce small elements near sharp boundaries. Is it possible for me to tell it to leave alone the boundary meshing and only insert nodes within the boundary? Thanks for your kind support. Best wishes, Michel Michel Audette, Ph.D. Assistant Professor,
Department of Modeling,
Simulation and Visualization Engineering,
Old Dominion University,
Norfolk, VA.
-- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis |
- [cgal-discuss] would like to understand how the facet and cell size objectives, and node insertion, work in Mesh_3, Audette, Michel A., 07/22/2013
- Re: [cgal-discuss] would like to understand how the facet and cell size objectives, and node insertion, work in Mesh_3, Mariette Yvinec, 07/23/2013
- RE: [cgal-discuss] would like to understand how the facet and cell size objectives, and node insertion, work in Mesh_3, Audette, Michel A., 07/23/2013
