cgal-discuss - Re: [cgal-discuss] 2D Polygon difference asserting in error
  • To:
  • Subject: Re: [cgal-discuss] 2D Polygon difference asserting in error
  • Date: Tue, 23 Jul 2013 22:19:01 +0200
The first thing to try is to replace
typedef CGAL::Cartesian<Number_type> Kernel;
by
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
Sebastien.
On 07/23/2013 08:47 PM, Willy Lambert wrote:
Hi all,
I'm quite new to cgal, and I'm trying to use it in robotics path
planning. To do so I create a polygon with holes which show reachable
areas. I initiate a polygon set with the "outer" map and then do a
difference with each obstacles thougth eating borders of the map or
creating an hole.
It is working for many obstacles except one, which is asserting when I
do the difference. I didn't used cgal enougth to be able to find if it
is a cgal bug or a mis-use so I'm asking some help here to clarify this.
Here is a simple code to reproduce :
typedef float Number_type;
typedef Kernel::Point_2 Point_2;
typedef CGAL::Polygon_2<Kernel> Polygon_2;
typedef CGAL::Polygon_with_holes_2<Kernel> Polygon_with_holes_2;
typedef CGAL::Polygon_set_2<Kernel> Polygon_set_2;
Polygon_2 A,B;
A.push_back(Point_2(1350, -850));
A.push_back(Point_2(1350, 850));
A.push_back(Point_2(-1350, -850));
B.push_back(Point_2(1003, -116));
B.push_back(Point_2(947, -251));
B.push_back(Point_2(984, -1000));
Polygon_set_2 S;
S.insert(A);
S.difference(B);
It compiles and throw at execution :
(atlantronic) robot@ard-host ~/workspace/test_cgal/Debug $ ./test_cgal
terminate called after throwing an instance of
'CGAL::Precondition_exception'
what(): CGAL ERROR: precondition violation!
Expr: comp_f(object, parentP->object) != SMALLER
File: /home/robot/workspace/CGAL-4.2/include/CGAL/Multiset.h
Line: 2129
Aborted (core dumped)
Here is a screen shot if it can help visualizing the problem.
http://cgal-discuss.949826.n4.nabble.com/file/n4657830/cgal_problem.png
Let me know if you need any further information or if I need to
re-formulate my demand which standard debug information set.
Regards.
