cgal-discuss - Re: [cgal-discuss] 2D Polygon difference asserting in error
  • To:
  • Subject: Re: [cgal-discuss] 2D Polygon difference asserting in error
  • Date: Wed, 24 Jul 2013 01:22:00 +0200
(should I top post or down post on this list ?)
Thanks for answering. Could you tell me a bit more about what this would change ? It's not very clear for me what the Kernel is.
I modified the typedef and add :
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
Then I run into 2 types of problems :
_ I doesn't link (missing gmpq and mpfr), should I add anything (cmake config ? libraries to download) ?
_ I can't use A[0].x() to print things into console (it says :
Here is the build error :
Building target: test_cgal
Invoking: GCC C++ Linker
g++ -L/home/robot/workspace/CGAL-4.2/build/lib -o "test_cgal"  ./src/test_cgal.o   -lCGAL -lboost_thread-mt -lboost_system-mt
./src/test_cgal.o: In function `CGAL::Gmpq_rep::Gmpq_rep()':
/home/robot/workspace/CGAL-4.2/include/CGAL/GMP/Gmpq_type.h:51: undefined reference to `__gmpq_init'
./src/test_cgal.o: In function `CGAL::Gmpq_rep::~Gmpq_rep()':
/home/robot/workspace/CGAL-4.2/include/CGAL/GMP/Gmpq_type.h:52: undefined reference to `__gmpq_clear'
./src/test_cgal.o: In function `CGAL::Gmpq::Gmpq(int)':
/home/robot/workspace/CGAL-4.2/include/CGAL/GMP/Gmpq_type.h:87: undefined reference to `__gmpq_set_si'
./src/test_cgal.o: In function `CGAL::Gmpq::operator==(CGAL::Gmpq const&) const':
/home/robot/workspace/CGAL-4.2/include/CGAL/GMP/Gmpq_type.h:193: undefined reference to `__gmpq_equal'
./src/test_cgal.o: In function `CGAL::Gmpq::operator<(CGAL::Gmpq const&) const':
/home/robot/workspace/CGAL-4.2/include/CGAL/GMP/Gmpq_type.h:194: undefined reference to `__gmpq_cmp'
./src/test_cgal.o: In function `CGAL::Gmpq::operator==(int) const':
/home/robot/workspace/CGAL-4.2/include/CGAL/GMP/Gmpq_type.h:213: undefined reference to `__gmpq_cmp_si'
./src/test_cgal.o: In function `CGAL::Gmpq::operator<(int) const':
/home/robot/workspace/CGAL-4.2/include/CGAL/GMP/Gmpq_type.h:214: undefined reference to `__gmpq_cmp_si'
./src/test_cgal.o: In function `CGAL::Gmpq::operator-() const':
/home/robot/workspace/CGAL-4.2/include/CGAL/GMP/Gmpq_type.h:260: undefined reference to `__gmpq_neg'
./src/test_cgal.o: In function `CGAL::Gmpq::operator+=(CGAL::Gmpq const&)':
/home/robot/workspace/CGAL-4.2/include/CGAL/GMP/Gmpq_type.h:276: undefined reference to `__gmpq_add'
./src/test_cgal.o: In function `CGAL::Gmpq::operator-=(CGAL::Gmpq const&)':
/home/robot/workspace/CGAL-4.2/include/CGAL/GMP/Gmpq_type.h:286: undefined reference to `__gmpq_sub'
./src/test_cgal.o: In function `CGAL::Gmpq::operator*=(CGAL::Gmpq const&)':
/home/robot/workspace/CGAL-4.2/include/CGAL/GMP/Gmpq_type.h:296: undefined reference to `__gmpq_mul'
./src/test_cgal.o: In function `CGAL::Gmpq::operator/=(CGAL::Gmpq const&)':
/home/robot/workspace/CGAL-4.2/include/CGAL/GMP/Gmpq_type.h:307: undefined reference to `__gmpq_div'
./src/test_cgal.o: In function `CGAL::Real_embeddable_traits<CGAL::Gmpq>::To_interval::operator()(CGAL::Gmpq const&) const':
/home/robot/workspace/CGAL-4.2/include/CGAL/Gmpq.h:92: undefined reference to `mpfr_init2'
/home/robot/workspace/CGAL-4.2/include/CGAL/Gmpq.h:93: undefined reference to `mpfr_set_q'
/home/robot/workspace/CGAL-4.2/include/CGAL/Gmpq.h:94: undefined reference to `mpfr_get_d'
/home/robot/workspace/CGAL-4.2/include/CGAL/Gmpq.h:95: undefined reference to `mpfr_set_q'
/home/robot/workspace/CGAL-4.2/include/CGAL/Gmpq.h:96: undefined reference to `mpfr_get_d'
/home/robot/workspace/CGAL-4.2/include/CGAL/Gmpq.h:97: undefined reference to `mpfr_clear'
collect2: error: ld returned 1 exit status
2013/7/23 Sebastien Loriot (GeometryFactory) <>
The first thing to try is to replace
typedef CGAL::Cartesian<Number_type> Kernel;
by
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
Sebastien.
On 07/23/2013 08:47 PM, Willy Lambert wrote:
Hi all,
I'm quite new to cgal, and I'm trying to use it in robotics path
planning. To do so I create a polygon with holes which show reachable
areas. I initiate a polygon set with the "outer" map and then do a
difference with each obstacles thougth eating borders of the map or
creating an hole.
It is working for many obstacles except one, which is asserting when I
do the difference. I didn't used cgal enougth to be able to find if it
is a cgal bug or a mis-use so I'm asking some help here to clarify this.
Here is a simple code to reproduce :
typedef float Number_type;
typedef Kernel::Point_2 Point_2;
typedef CGAL::Polygon_2<Kernel> Polygon_2;
typedef CGAL::Polygon_with_holes_2<Kernel> Polygon_with_holes_2;
typedef CGAL::Polygon_set_2<Kernel> Polygon_set_2;
Polygon_2 A,B;
A.push_back(Point_2(1350, -850));
A.push_back(Point_2(1350, 850));
A.push_back(Point_2(-1350, -850));
B.push_back(Point_2(1003, -116));
B.push_back(Point_2(947, -251));
B.push_back(Point_2(984, -1000));
Polygon_set_2 S;
S.insert(A);
S.difference(B);
It compiles and throw at execution :
(atlantronic) robot@ard-host ~/workspace/test_cgal/Debug $ ./test_cgal
terminate called after throwing an instance of
'CGAL::Precondition_exception'
   what():  CGAL ERROR: precondition violation!
Expr: comp_f(object, parentP->object) != SMALLER
File: /home/robot/workspace/CGAL-4.2/include/CGAL/Multiset.h
Line: 2129
Aborted (core dumped)
Here is a screen shot if it can help visualizing  the problem.
http://cgal-discuss.949826.n4.nabble.com/file/n4657830/cgal_problem.png
Let me know if you need any further information or if I need to
re-formulate my demand which standard debug information set.
Regards.
