- To:
- Subject: [cgal-discuss] Check if vertex was inserted inside input constraint
- Date: Fri, 26 Jul 2013 16:28:24 -0500
Hello,
![Inline image 2]()
For example. I inserted points and a constraint on a Constrained Delaunay Triangulation, like this:
Vertex_handle va = cdt.insert(Point(2,2));
Vertex_handle vb = cdt.insert(Point(-2,2));
Vertex_handle vc = cdt.insert(Point(2,-2));
Vertex_handle vd = cdt.insert(Point(-2,-2));
cdt.insert_constraint(vb, vc);
Vertex_handle vertex_in_const = cdt.insert(Point(-1, 1));
Vertex_handle vertex_in_const = cdt.insert(Point(0,0));
Vertex_handle vertex_in_const = cdt.insert(Point(1,-1));
This generates the triangulation attached.
So there are 3 points inserted on the constrained. How can I check if a vertex is on this case (inserted on a constrained) ?.
I only know about iterating constraints, and check is a vertex isn't one of the vertices that form this constraint, and then check if the the Point is inside the Line that forms this constrained. Isn't there a better and faster solution?
Thank you.
Raul O. Gallegos Hidalgo
Description: PNG image
- [cgal-discuss] Check if vertex was inserted inside input constraint, Raul Gallegos, 07/26/2013
- Re: [cgal-discuss] Check if vertex was inserted inside input constraint, Winnie, 07/27/2013
- Re: [cgal-discuss] Check if vertex was inserted inside input constraint, Raul Gallegos, 07/27/2013
