cgal-discuss - Re: [cgal-discuss] Check if vertex was inserted inside input constraint
  • To:
  • Subject: Re: [cgal-discuss] Check if vertex was inserted inside input constraint
  • Date: Sat, 27 Jul 2013 00:05:36 +0200
So there are 3 points inserted on the constrained. How can I check if a
vertex is on this case (inserted on a constrained) ?.
Are you looking for ct.are_there_incident_constraints( Vertex_handle v ) ?
https://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Constrained_triangulation_2.html#Function_bool_are_there_incident_constraints6Vertex_handle_v9;
