cgal-discuss - Re: [cgal-discuss] How to use AABB Tree correctly?
  • To:
  • Subject: Re: [cgal-discuss] How to use AABB Tree correctly?
  • Date: Mon, 26 Aug 2013 10:27:10 +0200
Le dimanche 25 août 2013 04:06:18 ChaoM a écrit :
> Hello everybody:
> Now i meet this problem: I have three models , these models are
> simple geometric objecets. Such as: halfsphere, Clylinder, Cube and so on !
> All these models have the trianglated surface(that is , the surface of the
> models is made of a mount of triangles).
> What i want to do is use the AABB Tree to get the intersection of
> these three models. In my point , i do not use the AABB Tree correctly
> ,because i just use "do_intersect" function to judge a triangle of one
> models if intersect a triangle of another models .
For your scenario, you better use the package named "Intersecting Sequences
of
dD Iso-oriented Boxes". The AABB package is best use when you have a bit data
set of triangles that are fixed (the model), and a lot of intersection
queries
to it.
In your scenario, it seems that you have several models, that are fixed. AABB
trees are not well adapted for that.
Laurent Rineau, PhD
