- To:
- Subject: [cgal-discuss] Re: How to use AABB Tree correctly?
- Date: Mon, 26 Aug 2013 03:22:03 -0700 (PDT)
Hello Laurent:
Thank you for your good advice. In my past research , I do use the
AABB Tree to sovle the Boolean Operation (For example : two half sphere
intersects), when the surface of the model consists a lot of triangles ,the
time of computing intersection is very large! So i will take your advice~~
For another question, i also use the Nef to solve polyhedron Boolean
Operation , but i find it cost too,too,too many time. And I wanna to
know,whether the CGAL lib or other open lib can sovle the Boolean Operation
of 3D geometric polyhedrons. If exits, is there any request for constructing
the model?(Such as :not too many triangles, or precision of the model)?
Because i know the 2D Boolean Operation is very mature, so i want to
know whether there is a good solution for the 3D Boolean Operation for any
3D geometric Objects!
So please point me out , Thanks.
Yours Chao M
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-to-use-AABB-Tree-correctly-tp4657967p4657970.html
- [cgal-discuss] How to use AABB Tree correctly?, ChaoM, 08/25/2013
- Message not available
- Re: [cgal-discuss] How to use AABB Tree correctly?, Sartaj Hundal, 08/26/2013
- [cgal-discuss] Re: How to use AABB Tree correctly?, ChaoM, 08/26/2013
- Re: [cgal-discuss] How to use AABB Tree correctly?, Laurent Rineau (CGAL/GeometryFactory), 08/26/2013
