- To:
- Subject: [cgal-discuss] Using Polyhedron fill_hole()
- Date: Mon, 26 Aug 2013 12:21:57 +0100
Hi
I have been trying to use the fill_hole method described here http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron_ref/Class_Polyhedron_3.html to fill a number of holes in a 3D polyhedron that I have to process. However I am unable to get it working. After calling the fill hole I still have the same number of border halfedges and the polygon is not closed. An additional face is inserted but it does not seem to close the polyhedron.
Attached is a minimal example based on a modification of the off2stl example. I load a closed off polyhedron and make a hole in it which seems to work as expected. However the closing of the hole using "P.fill_hole(P.border_halfedges_begin());" does not work as expected. Is there a missing update function or can someone spot something else obvious that I have done wrong.
This is done using CGAL 4.2, I have not yet tried the 4.3 beta.
Thanks
Jens H Nielsen
// Make and fill hole in surface modified from off2stl example.
// Convert from OFF format to StereoLithography StL format.
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/IO/Polyhedron_iostream.h>
#include <CGAL/IO/Verbose_ostream.h>
#include <cstddef>
#include <cstdlib>
#include <cstring>
#include <iostream>
#include <fstream>
using namespace std;
bool verbose = false;
bool binary = false;
typedef CGAL::Simple_cartesian<double> Kernel;
typedef Kernel::Point_3 Point;
typedef Kernel::Vector_3 Vector;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
typedef Polyhedron::Vertex_iterator Vertex_iterator;
typedef Polyhedron::Facet_iterator Facet_iterator;
typedef Polyhedron::Halfedge_iterator Halfedge_iterator;
typedef Polyhedron::Halfedge_handle Halfedge_handle;
// main function with standard unix commandline arguments
int main( int argc, char **argv) {
int n = 0; // number of filenames
char *filename[2];
bool help = false;
for (int i = 1; i < argc; i++) { // check commandline options
if ( strcmp( "-v", argv[i]) == 0)
verbose = true;
else if ( strcmp( "-b", argv[i]) == 0)
binary = true;
else if ( (strcmp( "-h", argv[i]) == 0) ||
(strcmp( "-help", argv[i]) == 0))
help = true;
else if ( n < 2 ) {
filename[ n++] = argv[i];
} else {
++n;
break;
if ((n > 2) || help) {
if ( ! help)
cerr << "Error: in parameter list" << endl;
cerr << "Usage: " << argv[0] << " [<options>] [<infile> [<outfile>]]"
<< endl;
cerr << " convert a CGAL object (OFF) to StereoLithography StL "
"format." << endl;
cerr << " -v verbose." << endl;
cerr << " -b binary." << endl;
exit( ! help);
CGAL::Verbose_ostream vout( verbose);
vout << argv[0] << ": verbosity on." << endl;
const char* iname = "cin";
istream* p_in = &cin;
ifstream in;
if ( n > 0) {
in.open( filename[0]);
p_in = ∈
iname = filename[0];
if ( !*p_in) {
cerr << argv[0] << ": error: cannot open file '"<< iname
<< "' for reading." <<endl;
exit( 1);
vout << "Reading polyhedron ..." << endl;
Polyhedron P;
(*p_in) >> P;
vout << " .... done." << endl;
if ( !*p_in) {
cerr << argv[0] << " read error: while reading file '"<< iname << "'."
<< endl;
exit( 1);
cout << "Surface loaded" << endl;
P.normalize_border();
cout << P.is_closed () << endl;
cout << P.size_of_vertices() << endl;
cout << P.size_of_halfedges() << endl;
cout << P.size_of_border_halfedges () << endl;
cout << P.size_of_facets() << endl;
cout << "Make a Hole" << endl;
P.make_hole(P.halfedges_begin());
cout << P.size_of_border_halfedges() << endl;
cout << P.is_closed() << endl;
Halfedge_iterator j;
for (j = P.border_halfedges_begin(); j != P.halfedges_end(); ++j){
cout << j->vertex()->point() << " " << j->opposite()->vertex()->point() << endl;
cout << "And Filling" << endl;
return 0;
// EOF //
// Make and fill hole in surface modified from off2stl example. // Convert from OFF format to StereoLithography StL format. #include <CGAL/Simple_cartesian.h> #include <CGAL/Polyhedron_3.h> #include <CGAL/IO/Polyhedron_iostream.h> #include <CGAL/IO/Verbose_ostream.h> #include <cstddef> #include <cstdlib> #include <cstring> #include <iostream> #include <fstream> using namespace std; bool verbose = false; bool binary = false; typedef CGAL::Simple_cartesian<double> Kernel; typedef Kernel::Point_3 Point; typedef Kernel::Vector_3 Vector; typedef CGAL::Polyhedron_3<Kernel> Polyhedron; typedef Polyhedron::Vertex_iterator Vertex_iterator; typedef Polyhedron::Facet_iterator Facet_iterator; typedef Polyhedron::Halfedge_iterator Halfedge_iterator; typedef Polyhedron::Halfedge_handle Halfedge_handle; // main function with standard unix commandline arguments // ------------------------------------------------------ int main( int argc, char **argv) { int n = 0; // number of filenames char *filename[2]; bool help = false; for (int i = 1; i < argc; i++) { // check commandline options if ( strcmp( "-v", argv[i]) == 0) verbose = true; else if ( strcmp( "-b", argv[i]) == 0) binary = true; else if ( (strcmp( "-h", argv[i]) == 0) || (strcmp( "-help", argv[i]) == 0)) help = true; else if ( n < 2 ) { filename[ n++] = argv[i]; } else { ++n; break; } } if ((n > 2) || help) { if ( ! help) cerr << "Error: in parameter list" << endl; cerr << "Usage: " << argv[0] << " [<options>] [<infile> [<outfile>]]" << endl; cerr << " convert a CGAL object (OFF) to StereoLithography StL " "format." << endl; cerr << " -v verbose." << endl; cerr << " -b binary." << endl; exit( ! help); } CGAL::Verbose_ostream vout( verbose); vout << argv[0] << ": verbosity on." << endl; const char* iname = "cin"; istream* p_in = &cin; ifstream in; if ( n > 0) { in.open( filename[0]); p_in = ∈ iname = filename[0]; } if ( !*p_in) { cerr << argv[0] << ": error: cannot open file '"<< iname << "' for reading." <<endl; exit( 1); } vout << "Reading polyhedron ..." << endl; Polyhedron P; (*p_in) >> P; vout << " .... done." << endl; if ( !*p_in) { cerr << argv[0] << " read error: while reading file '"<< iname << "'." << endl; exit( 1); } cout << "Surface loaded" << endl; P.normalize_border(); cout << P.is_closed () << endl; cout << P.size_of_vertices() << endl; cout << P.size_of_halfedges() << endl; cout << P.size_of_border_halfedges () << endl; cout << P.size_of_facets() << endl; cout << "Make a Hole" << endl; P.make_hole(P.halfedges_begin()); P.normalize_border(); cout << P.size_of_border_halfedges() << endl; cout << P.is_closed() << endl; cout << P.size_of_vertices() << endl; cout << P.size_of_halfedges() << endl; cout << P.size_of_border_halfedges () << endl; cout << P.size_of_facets() << endl; Halfedge_iterator j; for (j = P.border_halfedges_begin(); j != P.halfedges_end(); ++j){ cout << j->vertex()->point() << " " << j->opposite()->vertex()->point() << endl; } cout << "And Filling" << endl; P.fill_hole(P.border_halfedges_begin()); P.normalize_border(); cout << P.size_of_border_halfedges() << endl; cout << P.is_closed () << endl; cout << P.size_of_vertices() << endl; cout << P.size_of_halfedges() << endl; cout << P.size_of_border_halfedges () << endl; cout << P.size_of_facets() << endl; for (j = P.border_halfedges_begin(); j != P.halfedges_end(); ++j){ cout << j->vertex()->point() << " " << j->opposite()->vertex()->point() << endl; } return 0; } // EOF //
- [cgal-discuss] Using Polyhedron fill_hole(), Jens Nielsen, 08/26/2013
