- To:
- Subject: Re: [cgal-discuss] A valid Polyhedron_3 surface
- Date: Fri, 30 Aug 2013 17:18:09 +0200
Le vendredi 30 août 2013 07:51:04 gupta61 a écrit :
> Hi,
> I was wondering if it is possible to have a surface defined by Polyhedron_3
> with different/opposite normal orientation of facets?
> All facets of my surface are triangles. My understanding is that the normals
> of all the triangles/facets should point in the same direction. And if this
> condition is violated, I should get an error. Am I missing something here?
No. If two facets of a polyhedron share an edge, then the orientations of the
two facets must be coherent.
Laurent Rineau, PhD
- [cgal-discuss] A valid Polyhedron_3 surface, gupta61, 08/30/2013
- Re: [cgal-discuss] A valid Polyhedron_3 surface, Laurent Rineau (CGAL/GeometryFactory), 08/30/2013
- [cgal-discuss] Re: A valid Polyhedron_3 surface, gupta61, 08/30/2013
