cgal-discuss - Re: [cgal-discuss] CGAL 4.1 make error Win7
  • To:
  • Subject: Re: [cgal-discuss] CGAL 4.1 make error Win7
  • Date: Mon, 23 Sep 2013 12:24:50 +0200
Le dimanche 22 septembre 2013 04:38:48 mytien a écrit :
> Hey,
> I am trying to compile CGAL 4.1 to use it in my applications.
> So far I managed configuration with CMake, I chose MinGW and successfully
> generated a Makefile.
> when trying to build CGAL with make, i receive following output:
> Scanning dependencies of target CGAL
> [ 16%] Building CXX object src/CGAL/CMakeFiles/CGAL.dir/all_files.cpp.obj
> [ 33%] Building RC object src/CGAL/CMakeFiles/CGAL.dir/CGAL_verinfo.rc.obj
> Linking CXX shared library ..\..\bin\libCGAL.dll
> ..\..\..\auxiliary\gmp\lib\libmpfr-4.dll: file not recognized: File format
> not recognized
> collect2: ld returned 1 exit status
> make[2]: *** [bin/libCGAL.dll] error 1
> make[1]: *** [src/CGAL/CMakeFiles/CGAL.dir/all] error 2
> make: *** [all] errors 2
> Somehow my "bin" folder is empty, also I dont have an "all" file in
> "src/CGAL/CMakeFiles/CGAL.dir/", only a file called "all_files.cpp.obj".
> I don't know if this is important but here are my CMakeCache.txt and the
> Makefile generated by CMake:
> Makefile <http://cgal-discuss.949826.n4.nabble.com/file/n4658063/Makefile>
> CMakeCache.txt
> <http://cgal-discuss.949826.n4.nabble.com/file/n4658063/CMakeCache.txt>
> Any ideas?
In do not know how you ended up with that CMake configuration. Your CMake variables GMP_LIBRARIES and MPFR_LIBRARIES both are the path to .dll files, where they should be .lib files. Once you fix that, the compilation should go on.
Laurent Rineau, PhD
