Re: [cgal-discuss] Why my volumes of convex hull and alpha shape are almost the same?
- To:
- Subject: Re: [cgal-discuss] Why my volumes of convex hull and alpha shape are almost the same?
- Date: Tue, 24 Sep 2013 22:26:35 -0700 (PDT)
Thank you so much!
You are right. I should make sure the exterior cell are not included in
calculating the alpha shape volume. So my program ends up to be:
for(Alpha_shape_3::Finite_cells_iterator it = as.finite_cells_begin(); it !=
as.finite_cells_end(); it++)
if(as.classify(it)==Alpha_shape_3::INTERIOR)
Tetrahedron_3 tetr = as.tetrahedron(it);
alpha_volume += tetr.volume();
Also thanks to Mariette, even I did not find a way to test the
"alpha_spectrum".
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Why-my-volumes-of-convex-hull-and-alpha-shape-are-almost-the-same-tp4658070p4658076.html
- [cgal-discuss] Why my volumes of convex hull and alpha shape are almost the same?, evantong623, 09/23/2013
- Re: [cgal-discuss] Why my volumes of convex hull and alpha shape are almost the same?, Mariette Yvinec, 09/24/2013
- Re: [cgal-discuss] Why my volumes of convex hull and alpha shape are almost the same?, Sebastien Loriot (GeometryFactory), 09/24/2013
- Re: [cgal-discuss] Why my volumes of convex hull and alpha shape are almost the same?, evantong623, 09/25/2013
