- To:
- Subject: Re: [cgal-discuss] NaN calculating intersection point of plane and line
- Date: Fri, 27 Sep 2013 13:43:56 +0200
On 09/27/2013 01:40 PM, Martin Uhrin wrote:
Dear CGAL community,
I'm having problems calculating the intercept of a plane and a line.
To give one example, the result of an intersection gives me a points
that streams out as:
4 5.38925e+2284/9.43119e+2284 0/9.43119e+2284 0/9.43119e+2284 0/1.23183e+2285
This is indeed the answer I expect (0.57.. 0 0 0) but represented in
this format I can't get a sensible double out (using to_double),
presumably as it's converting the numerator and denominator to doubles
and then expects to be able to do the division.
Background:
I'm generating a convex hull with using:
Try replacing:
typedef CORE::Expr NT;by:
typedef CGAL::Quotient< NT> RT;
typedef CORE::Expr RT;
Did you find this in one of our examples?
Sebastien.
typedef CGAL::Cartesian_d<RT> Kernel;
typedef CGAL::Convex_hull_d< Kernel> Hull;
I need a number type that supports quotients and general square roots
and this was the only way (other than using using LEDA which I'd
rather avoid) that I could think of.
To get the intercept I use:
Kernel::Intersect_d intersect = Kernel().intersect_d_object();
... = intersect(line, hyperplane);
where hyperplane is supporting a facet of my hull.
Any ideas on how I can get a sensible double out would be much appreciated.
Kind regards,
-Martin
- [cgal-discuss] NaN calculating intersection point of plane and line, Martin Uhrin, 09/27/2013
- Re: [cgal-discuss] NaN calculating intersection point of plane and line, Sebastien Loriot (GeometryFactory), 09/27/2013
- Re: [cgal-discuss] NaN calculating intersection point of plane and line, Martin Uhrin, 09/27/2013
- [cgal-discuss] calculating intersection point of plane and line, llduncan, 09/27/2013
