- To:
- Subject: Re: [cgal-discuss] NaN calculating intersection point of plane and line
- Date: Fri, 27 Sep 2013 06:38:44 -0700 (PDT)
Wow, fantastic, this seems to have worked perfectly. Thanks Sebastien!
No, this isn't from an example, this is my mistake. I started from:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Convex_hull_3/Chapter_main.html#Subsection_16.3.1
Which uses
typedef CGAL::Quotient<CGAL::MP_Float> RT;
Which I then expanded to encompass the ring type I needed.
So to clarify my mistake: From your answer and my now working code I
presume Expr already supports quotients. In which case my code was
unnecessarily wrapping Expr in a CGAL::Quotient resulting in the strange
output (but otherwise functioning code). Is this all correct?
Again, thanks for your speedy reply.
-Martin
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/NaN-calculating-intersection-point-of-plane-and-line-tp4658086p4658088.html
- [cgal-discuss] NaN calculating intersection point of plane and line, Martin Uhrin, 09/27/2013
- Re: [cgal-discuss] NaN calculating intersection point of plane and line, Sebastien Loriot (GeometryFactory), 09/27/2013
- Re: [cgal-discuss] NaN calculating intersection point of plane and line, Martin Uhrin, 09/27/2013
- [cgal-discuss] calculating intersection point of plane and line, llduncan, 09/27/2013
