cgal-discuss - Re: [cgal-discuss] Constrained Delaunay Triangulation, finding edges in polygons
  • To:
  • Subject: Re: [cgal-discuss] Constrained Delaunay Triangulation, finding edges in polygons
  • Date: Mon, 30 Sep 2013 16:20:05 +0200
On Mon, 2013-09-30 at 10:17 +0200, Mariette Yvinec wrote:
> The solution of Michael won't work if the polygonal regions
> you are tracking are not simply connected and convex.
> Here is a more general solution.
> Starting from the examples that mark the triangular faces inside the polgon
> it is easy to get the edges inside the polygons:
> these are the edges adjacent to two marked polygons.
Thanks for that hint.
Yes, I understand (now) that it may fail for non convex polygons. I
guess that I will have only convex ones.
Currently I can not fully understand your suggestion
For my case I may have only one polygon (or more than one but with large
distance to each other). I want to find the inner edges, as stated in my
first posting. I can not see how that may work for non convex polygons
now -- have to do some thinking...
Best regards
Stefan Salewski
