cgal-discuss - Re: [cgal-discuss] Constrained Delaunay Triangulation, finding edges in polygons
  • To:
  • Subject: Re: [cgal-discuss] Constrained Delaunay Triangulation, finding edges in polygons
  • Date: Mon, 30 Sep 2013 23:19:09 +0200
On Mon, 2013-09-30 at 10:04 -0500, John Griessen wrote:
> On 09/30/2013 09:20 AM, Stefan Salewski wrote:
> >> these are the edges adjacent to two marked polygons
> > For my case I may have only one polygon (or more than one but with large
> > distance to each other). I want to find the inner edges,
> The triangles are polygons that are adjacent, have adjacent edges, and are
> always convex. That lets you find inner edges if all are marked as being
> part of
> a larger non-convex polygon and whether they are part of a particular
> triangle.
> For triangles that are a subset of the larger non-convex polygon:
> If a triangle edge is part of a triangle and also part of an adjacent
> triangle,
> then it is interior.
> You can mark "part of" or "outside of" the larger non-convex polygon
> as you go, right? It is what you start with, then create Delaunay
> triangles from, right?
Thanks, now I understand the idea!
For the implementation I may still have some problems, because my
triangulation is currently vertex-based
(http://www.ssalewski.de/CDT.html.en) based on some CGAL example code,
and indeed vertex-based makes sense for my application, because my main
task is iterating over all vertices in the triangulation and finding all
neighbor vertices. I have to investigate if I am able to label faces in
an vertex-based constrained delaunay triangulation.
But fortunately my constrained polygons are convex, so I always can used
the simpler solution.
Thanks,
Stefan Salewski
