- To: "" <>
- Subject: Re: [cgal-discuss] 3D Identity
- Date: Thu, 3 Oct 2013 02:48:05 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Rocket-MIMEInfo:X-Mailer:References:Message-ID:Date:From:Reply-To:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=Qy7MHvLj3Ax86H8I6ZrdabeNGZLau6KuIk+ywh0xgaWPsxn78EtnM/5tmzIzmoOzovAmbmOiqNVezorNDlauSsnlhOtgEwKDPlhfRFxv5fojI+0kKWHebgzqHweRadq1aDvV3eAC3UrfvaG7yuG8fqtYmqtzR8FFP0aCRD3Jxtw=;
Thanks for reply
To: "" <>
Sent: Thursday, October 3, 2013 10:55 AM
Le jeudi 03 octobre 2013 01:43:37 khaldon hmesheh a écrit :
> Hello,
> I am searching for some algorithms to check if two 3D triangulated Shapes
> are identical. See attachement. Any suggestions or help.
>Search the web for "3d shape descriptors". There are a lot of articles! On the
>other hand, that also means that the subject is not fully solved with a single
>solution that fits all needs.
I searched for such algorithms but as you said it is not fully solved and my problem is to decide if two parts are identical for tolerances less than 1mm.
>Anyway, there is nothing ready to use in CGAL, as far as I know, but you can
>use CGAL to implement any algorithm found in one of the articles on the
>subject.
>With a second though, it seems that your problem may be more simple that the
>general shape recognition. You could use the AABB Tree from CGAL to compute
>the Haussdorf between your two surfaces, and decide that they are sufficiently
>similar if that distance is lower that a given bound.
I have applied Fréchet distance for 2D shapes and it returned a very satisfactory result.But I never used for 3D shapes. You mean that Hausdorff Distance is also applicable for 3D surfaces.
Laurent Rineau, PhD
- [cgal-discuss] 3D Identity, khaldon hmesheh, 10/03/2013
- Re: [cgal-discuss] 3D Identity, Sebastien Loriot (GeometryFactory), 10/03/2013
- Re: [cgal-discuss] 3D Identity, khaldon hmesheh, 10/03/2013
- Re: [cgal-discuss] 3D Identity, Laurent Rineau (CGAL/GeometryFactory), 10/03/2013
- Re: [cgal-discuss] 3D Identity, Henrik Zimmer, 10/08/2013
- Re: [cgal-discuss] 3D Identity, khaldon hmesheh, 10/08/2013
- Re: [cgal-discuss] 3D Identity, Henrik Zimmer, 10/09/2013
- Re: [cgal-discuss] 3D Identity, khaldon hmesheh, 10/10/2013
- Re: [cgal-discuss] 3D Identity, John Griessen, 10/08/2013
