- To:
- Subject: Re: [cgal-discuss] 3D Identity
- Date: Tue, 08 Oct 2013 10:24:56 -0500
On 10/03/2013 03:55 AM, Laurent Rineau (CGAL/GeometryFactory) wrote:
With a second though, it seems that your problem may be more simple that the
general shape recognition. You could use the AABB Tree from CGAL to compute
the Haussdorf between your two surfaces, and decide that they are sufficiently
similar if that distance is lower that a given bound.
Hmmm... If that approach computes quickly enough, one could generate a set
of orientations and scalings until a near match was optimized... A fuzzy
logic comparator.
- [cgal-discuss] 3D Identity, khaldon hmesheh, 10/03/2013
- Re: [cgal-discuss] 3D Identity, Sebastien Loriot (GeometryFactory), 10/03/2013
- Re: [cgal-discuss] 3D Identity, khaldon hmesheh, 10/03/2013
- Re: [cgal-discuss] 3D Identity, Laurent Rineau (CGAL/GeometryFactory), 10/03/2013
- Re: [cgal-discuss] 3D Identity, Henrik Zimmer, 10/08/2013
- Re: [cgal-discuss] 3D Identity, khaldon hmesheh, 10/08/2013
- Re: [cgal-discuss] 3D Identity, Henrik Zimmer, 10/09/2013
- Re: [cgal-discuss] 3D Identity, khaldon hmesheh, 10/10/2013
- Re: [cgal-discuss] 3D Identity, John Griessen, 10/08/2013
