cgal-discuss - [cgal-discuss] Bug Report: Setup 4.2 fails to download taucs library
  • To:
  • Subject: [cgal-discuss] Bug Report: Setup 4.2 fails to download taucs library
  • Date: Fri, 4 Oct 2013 12:47:27 -0700 (PDT)
1) Run CGAL-4.2-Setup.exe
2) Tic checkbox [x] LAPACK and TAUCS precompiled libs
3) Proceed to install
> Installation succeeds up to and including the download of gmp and mpfr.
> The following error message appears:
CGAL-4.2 Setup
Unable to download
https://cgal.geometryfactory.com/CGAL/precompiled_libs/auxiliary/win32/TAUCS-CGAL-3.7/taucs.h.zip.
Error: File Open Error
OK
> The error message reappears for the following files:
taucs.h.zip
taucs_private.h.zip
taucs_config_tests.h.zip
taucs_config_build.h.zip
blaswrap.h.zip
taucs-libs.zip
> Windows reports that this program might not have been installed properly.
4) Open the link
in a browser.
> The directory is accessible and the files can easily be downloaded
> manually.
The OS is Windows 8.
The PC is member of a company intranet; internet is accessed through a
company firewall.
Probable Fix:
The CGAL setup should use the internet settings (i.e. proxy, etc.) from the
windows control panel to access the internet.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Bug-Report-Setup-4-2-fails-to-download-taucs-library-tp4658131.html
