cgal-discuss - Re: [cgal-discuss] Bug Report: Setup 4.2 fails to download taucs library
  • To:
  • Subject: Re: [cgal-discuss] Bug Report: Setup 4.2 fails to download taucs library
  • Date: Mon, 07 Oct 2013 15:01:42 +0200
Le vendredi 04 octobre 2013 12:47:27 Dr. Frank Heimes a écrit :
> 1) Run CGAL-4.2-Setup.exe
> 2) Tic checkbox [x] LAPACK and TAUCS precompiled libs
> 3) Proceed to install
> > Installation succeeds up to and including the download of gmp and mpfr.
> > The following error message appears:
> Unable to download
> https://cgal.geometryfactory.com/CGAL/precompiled_libs/auxiliary/win32/TAUCS
> -CGAL-3.7/taucs.h.zip. Error: File Open Error
> > 4) Open the link
> -CGAL-3.7/ in a browser.
> > The directory is accessible and the files can easily be downloaded
> > manually.
> The OS is Windows 8.
> The PC is member of a company intranet; internet is accessed through a
> company firewall.
> Probable Fix:
> The CGAL setup should use the internet settings (i.e. proxy, etc.) from the
> windows control panel to access the internet.
Dear Dr. Heimes,
I want first to thank you for that detailed report.
Our Windows installer uses the NSIS Inetc plugin:
http://nsis.sourceforge.net/Inetc_plug-in
That plugin is documented to use the Windows proxy settings (at least those configured for Internet Explorer).
Can you try again with CGAL-4.3-beta1-Setup.exe? In that last version of CGAL, I have fixed a bug in the installer that could be related to the error you got (File Open Error), but is not related to proxies: the error may be that the destination directories do not exist. Do you have the following empty directories in your distribution of CGAL-4.2?
auxiliary\taucs\include
auxiliary\taucs\lib
Is that bug specific to TAUCS/LAPACK, or does it occur also if you tic the GMP/MPFR checkbox?
Best regards,
Laurent Rineau
Laurent Rineau, PhD
