- To:
- Subject: [cgal-discuss] Test if polyhedron facet is finite
- Date: Fri, 11 Oct 2013 15:15:01 -0700 (PDT)
Hi,
How do I check if a facet in a polyhedron_3 object (disc topology) is
finite?
More specifically I have a half border edge and its opposite, and I want to
know which one belongs to the infinite face.
BTW, how did I miss that in the poly3 doc?
Zohar
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Test-if-polyhedron-facet-is-finite-tp4658182.html
- [cgal-discuss] Test if polyhedron facet is finite, Zohar, 10/12/2013
- Re: [cgal-discuss] Test if polyhedron facet is finite, Andreas Fabri, 10/12/2013
- Re: [cgal-discuss] Test if polyhedron facet is finite, Zohar, 10/12/2013
