- To:
- Subject: [cgal-discuss] Mesh simplification with edges marked as non-removable
- Date: Fri, 11 Oct 2013 08:20:04 -0700 (PDT)
Hi,
I am endeavouring to constrain the border edges of a 3D surface when I am
simplifying the mesh. However, the edges are not maintained in their
position. Please find an extract from the code below, I have used the
example provided in the manual and added a little to it. Is it the case that
below a stopping count threshold the constraint no longer works? I compared
the results of edges constrained and non-constrained and found that the
non-constrained was more faithful to the original mesh geometry for the same
stopping criterion! Any help or advice would be appreciated.
Thank you.
SMS::Count_stop_predicate<Surface> stop(80);
Constrains_map constrains_map ;
surface.normalize_border();
if ( surface.size_of_border_edges() != 0) {
std::cerr << "The input object has the following no of border edges:
" << surface.size_of_border_edges() << "\n";
for( Surface::Halfedge_iterator eb = surface.border_halfedges_begin(),
ee = surface.halfedges_end() ; eb != ee ; ++ eb )
constrains_map.set_is_constrained(eb,true);
int r = SMS::edge_collapse
(surface
,stop
,CGAL::vertex_index_map(boost::get(CGAL::vertex_external_index,surface))
.edge_index_map (boost::get(CGAL::edge_external_index ,surface))
.edge_is_border_map(constrains_map)
std::cout << "\nFinished...\n" << r << " edges removed.\n"
<< (surface.size_of_halfedges()/2) << " final edges.\n" ;
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Mesh-simplification-with-edges-marked-as-non-removable-tp4658180.html
- [cgal-discuss] Mesh simplification with edges marked as non-removable, costantinos, 10/11/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, Sebastien Loriot (GeometryFactory), 10/14/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, costantinos, 10/18/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, Sebastien Loriot (GeometryFactory), 10/22/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, costantinos, 10/24/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, Sebastien Loriot (GeometryFactory), 10/24/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, 柳米, 10/25/2013
