- To:
- Subject: Re: [cgal-discuss] openscad crashes while rendering
- Date: Sat, 12 Oct 2013 10:38:58 +0200
Hi,
On 10/12/2013 09:11 AM, GordieGii wrote:
> with the following error:
> pi@raspberrypi ~ $ openscad
> CGAL error: assertion violation!
> Expression : object_list_
> File : src/OGL_helper.h
> Line : 517
> Explanation:
> Refer to the bug-reporting instructions at
> http://www.cgal.org/bug_report.html
> Aborted
> I am running the latest Raspbian and LXDE.
> Anybody had this problem?
can you post the output of
uname -a
cat /etc/issue
dpkg -l | egrep "cgal|openscad"
(or some rpm/yum command to get the cgal/openscad version if your distribution
is not dpkg-based)
Joachim
- [cgal-discuss] openscad crashes while rendering, GordieGii, 10/12/2013
- Re: [cgal-discuss] openscad crashes while rendering, Joachim Reichel, 10/12/2013
- Re: [cgal-discuss] openscad crashes while rendering, GordieGii, 10/13/2013
- Re: [cgal-discuss] openscad crashes while rendering, Joachim Reichel, 10/13/2013
- Re: [cgal-discuss] openscad crashes while rendering, Marius Kintel, 10/13/2013
- Re: [cgal-discuss] openscad crashes while rendering, GordieGii, 10/16/2013
- Re: [cgal-discuss] openscad crashes while rendering, Joachim Reichel, 10/17/2013
- Re: [cgal-discuss] openscad crashes while rendering, GordieGii, 10/21/2013
- Re: [cgal-discuss] openscad crashes while rendering, 潘茂东, 10/21/2013
- Re: [cgal-discuss] openscad crashes while rendering, Sebastien Loriot (GeometryFactory), 10/22/2013
- Re: [cgal-discuss] openscad crashes while rendering, Marius Kintel, 10/16/2013
