- To:
- Subject: Re: [cgal-discuss] openscad crashes while rendering
- Date: Thu, 17 Oct 2013 19:18:52 +0200
Hi,
On 10/16/2013 06:54 AM, GordieGii wrote:
> That's the version that apt-get pulled from the raspbian repo when I
> installed it a couple days ago.
you could use the "testing" repository to get newer versions. But note that
"testing" is not "stable" (pun intended). But that won't solve your problem.
> So I have to see if I can downgrade to OpenGL 2.x or wait for somebody to
> port OpenSCAD to ES and the CGAL error is a red herring?
Either OpenSCAD/CGAL need to support OpenGL ES, or the Rasberry Pi needs to
support immediate-mode OpenGL.
Downgrading OpenGL won't help either. "2.x" was mentioned because "immediate
mode" was the only mode in that version. Never OpenGL versions still support
"immediate mode" (in addition to other modes).
Joachim
- [cgal-discuss] openscad crashes while rendering, GordieGii, 10/12/2013
- Re: [cgal-discuss] openscad crashes while rendering, Joachim Reichel, 10/12/2013
- Re: [cgal-discuss] openscad crashes while rendering, GordieGii, 10/13/2013
- Re: [cgal-discuss] openscad crashes while rendering, Joachim Reichel, 10/13/2013
- Re: [cgal-discuss] openscad crashes while rendering, Marius Kintel, 10/13/2013
- Re: [cgal-discuss] openscad crashes while rendering, GordieGii, 10/16/2013
- Re: [cgal-discuss] openscad crashes while rendering, Joachim Reichel, 10/17/2013
- Re: [cgal-discuss] openscad crashes while rendering, GordieGii, 10/21/2013
- Re: [cgal-discuss] openscad crashes while rendering, 潘茂东, 10/21/2013
- Re: [cgal-discuss] openscad crashes while rendering, Sebastien Loriot (GeometryFactory), 10/22/2013
- Re: [cgal-discuss] openscad crashes while rendering, Marius Kintel, 10/16/2013
- Re: [cgal-discuss] openscad crashes while rendering, GordieGii, 10/17/2013
