cgal-discuss - Re: [cgal-discuss] "Getting list of each interface facet between tetrahedrons"
  • To:
  • Subject: Re: [cgal-discuss] "Getting list of each interface facet between tetrahedrons"
  • Date: Tue, 15 Oct 2013 16:32:20 +0200
Le lundi 14 octobre 2013 23:50:44 Burak ER a écrit :
> Dear Cgal mail list subscribers,
> I am searching for a way to get interface facets between all the
> tetrahedras on a mesh. Therefore, every facet should have a self index
> and the tetrahedrons indices which it belongs to. For example;
> struct facet{
> int id;
> int tetrahedron_id1;//first tetrahedron
> int tetrahedron_id2;//second tetrahedron
> What is the best(fastest) way to solve this problem with cgal 3d
> meshing?
You can use the template CGAL::Triangulation_cell_base_with_info_3 to add extra member fields to the cells of CGAL 3D triangulations.
For example:
struct Cell_info {
int id;
Then, on a 3D triangulation, use the facets iterators:
std::vector<facet> all_facets; // container of 'facet' struct
int facet_id = 0;
for(Tr::Finite_facets_iterator
fit = tr.finite_facets_begin(),
end = tr.finite_facets_end(); fit !=end; ++fit)
Tr::Cell_handle cell = fit->first;
int index = fit->second;
Tr::Cell_handle other_cell = cell->neighbor(index);
// Then here you can use cell->info().id and other_cell->info().id
// to fill your container of facets.
facet new_facet = { facet_id++, cell->info().id, other_cell->info().id };
all_facets.push_back(new_facet);
In my opinion, you should use 'std::size_t' instead of 'int' as "id type".
Laurent Rineau, PhD
