- To:
- Subject: Re: [cgal-discuss] "Getting list of each interface facet between tetrahedrons"
- Date: Wed, 16 Oct 2013 18:21:43 +0200
Le mardi 15 octobre 2013 23:35:28 Burak ER a écrit :
> Your solution seems to get all the facets either they are interface or
> a surface facets. How can I determine the surface facets? A zero
> neighbor value indicates it as a surface facet?
If your surface mesh is in a C2t3 object (from the Surface Mesh Generator package), change the loop to:
for(C2t3::Facets_iterator
fit = c2t3.facets_begin(),
end = c2t3.facets_end(); fit !=end; ++fit)
If it is in a C3t3 object (from the 3D Mesh Generator package), change the loop to:
for(C3t3::Facets_in_complex_iterator
fit = c2t3.facets_in_complex_begin(),
end = c2t3.facets_in_complex_end(); fit !=end; ++fit)
In all cases, the value type of the iterators is Tr::Facet, that is a typedef for `std::pair<Tr::Cell_handle, int>`.
Laurent Rineau, PhD
- [cgal-discuss] "Getting list of each interface facet between tetrahedrons", Burak ER, 10/14/2013
- Re: [cgal-discuss] "Getting list of each interface facet between tetrahedrons", Laurent Rineau (CGAL/GeometryFactory), 10/15/2013
- Re: [cgal-discuss] "Getting list of each interface facet between tetrahedrons", Burak ER, 10/15/2013
- Re: [cgal-discuss] "Getting list of each interface facet between tetrahedrons", Laurent Rineau (CGAL/GeometryFactory), 10/16/2013
