- To:
- Subject: [cgal-discuss] Can not create CMakeLists.txt
- Date: Wed, 16 Oct 2013 15:14:06 -0700 (PDT)
Dear all,
I just installed CGAL-3.6.1 in ubuntu 12.04. I was able to build and run
the examples, but not the demos (but that doesn't bother me a lot at this
moment. I am eager to get started).
I am copying-pasting the same exact code from an example in a newly
created main.cpp file. Now I want to compile this file and run it.
From the "Installation Manual" on the site, I see that I need to do
something like that:
cd /path/to/program
cgal_create_CMakeLists -s executable <-- command not found!!
cmake -DCGAL_DIR=$HOME/CGAL-4.2 . <- I use 3.6.1 here
make
My script folder is this:
samaras@samaras-A15:~/CGAL-3.6.1/scripts$ ls
cgal_create_cmake_script cgal_make_macosx_app
so I am missing the cgal_create_CMakeLists? What should I do now?
If I do cmake, I receive this: CMake Error: The source directory
"/home/samaras/CGAL-3.6.1/projects" does not appear to contain
CMakeLists.txt.
Thanks you in advance,
George
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Can-not-create-CMakeLists-txt-tp4658221.html
- [cgal-discuss] Can not create CMakeLists.txt, Samaras, 10/17/2013
- Re: [cgal-discuss] Can not create CMakeLists.txt, Sebastien Loriot (GeometryFactory), 10/17/2013
- Re: [cgal-discuss] Can not create CMakeLists.txt, Samaras, 10/17/2013
