cgal-discuss - Re: [cgal-discuss] Can not create CMakeLists.txt
  • To:
  • Subject: Re: [cgal-discuss] Can not create CMakeLists.txt
  • Date: Wed, 16 Oct 2013 15:38:11 -0700 (PDT)
I thought so do, but did try with: cgal_create_cmake_script.txt -s source
Now, I tried with cgal_create_cmake_script and it is ok.
I had seen, when I was installing, at the manual to check at the link you
said. However, I am newer in Linux than in Cgal (had used it for a while in
Mac too) and I am not sure what I have to do with the two links one can find
there. If someone knows, I will be more than glad to try!
Thanks.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Can-not-create-CMakeLists-txt-tp4658221p4658224.html
