- To: "" <>
- Subject: RE: [cgal-discuss] Convex_hull_3 - CGAL
- Date: Thu, 24 Oct 2013 15:12:52 +0100
- Importance: Normal
Hi,
Thanks Sebastien for your answer.
I only need the index of the points, example:
Original Point Cloud:
point 1
point 2
point 3
point 4
Convex Hull:
point 3
point 4
I want to read the 3 and 4, to make them correspond in my further processing.
Thanks.
Nuno Pessanha Santos
> Date: Thu, 24 Oct 2013 07:11:37 +0200
> From:
> To:
> Subject: Re: [cgal-discuss] Convex_hull_3 - CGAL
> On 10/24/2013 05:31 AM, Nuno Pessanha Santos wrote:
> > Hi,
> > I am starting to use CGAL, and maybe this is a stupid question but I
> > need some help.
> > When you use the function "CGAL::convex_hull_3(points.begin(),
> > points.end(), Polyhedron_3 poly);" you obtain the polyhedron poly.
> > How can I read the obtained vertices or the points index that are
> > contained in the convex hull? I see so many examples but none of them
> > could help me in my task.
> Is the following what you are looking for?
> Polyhedron_3 poly;
> CGAL::convex_hull_3(points.begin(), points.end(), poly);
> std::vector<Point_3> chull_points(poly.points_begin(), poly.points_end());
> Sebastien
> > Thanks
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
> From:
> To:
> > Hi,
> > need some help.
> Polyhedron_3 poly;
> Sebastien
> > Thanks
- [cgal-discuss] Convex_hull_3 - CGAL, Nuno Pessanha Santos, 10/24/2013
- Re: [cgal-discuss] Convex_hull_3 - CGAL, Sebastien Loriot (GeometryFactory), 10/24/2013
- RE: [cgal-discuss] Convex_hull_3 - CGAL, Nuno Pessanha Santos, 10/24/2013
- Re: [cgal-discuss] Convex_hull_3 - CGAL, Philipp Moeller, 10/24/2013
