cgal-discuss - Re: [cgal-discuss] Convex_hull_3 - CGAL
  • To:
  • Subject: Re: [cgal-discuss] Convex_hull_3 - CGAL
  • Date: Thu, 24 Oct 2013 17:29:01 +0200
On 10/24/2013 05:22 PM, Nuno Pessanha Santos wrote:
Thanks Sebastien.
For my implementation every millisecond counts, I have to implement that
in the first way suggested by Sebastien.
One way to go is to define a new model of ConvexHullTraits_3 with std::size_t as point type. Then you redefine all the predicates by
forwarding to the default traits class, and the polyhedron points
will then be the indices.
Another question,I hope the final one.
When I make:
CGAL::convex_hull_3(points.begin(), points.end(), poly);
std::vector<Point_3> chull_points(poly.points_begin(), poly.points_end());
It´s not suppose to access the point 0 coordinate X by the:
std::cout << chull_points[0].x;
it's a function:
chull_points[0].x()
Sebastien.
This gives me the error:
"error C3867: 'CGAL::Point_3<R_>::x': function call missing argument
list; use '&CGAL::Point_3<R_>::x' to create a pointer to member"
Thanks.
> Date: Thu, 24 Oct 2013 16:51:32 +0200
> From:
> To:
> The only way to do it for now I think is to use the Delaunay
> triangulation.
> Note that it will take more time to compute than the other function.
> (I'll add a todo for adding this in a future release)
> Build the triangulation following this example:
http://doc.cgal.org/latest/Triangulation_3/index.html#Triangulation_3UsingtheBoostTransformIterator
> Then something like this should work (not tested):
> struct Chull_indices
> void operator()(Delaunay::Vertex_handle vh) const
> m_indices.push_back(vh->info());
> std::vector<std::size_t> m_indices;
> Chull_indices chull_indices;
> T.adjacent_vertices(T.infinite_vertex(),
> boost::make_function_output_iterator(chull_indices)
> for( std::size_t i : chull_indices.m_indices)
> std::cout << i << std::endl;
> Sebastien.
> On 10/24/2013 04:12 PM, Nuno Pessanha Santos wrote:
> > Hi,
> > Thanks Sebastien for your answer.
> > I only need the index of the points, example:
> > Original Point Cloud:
> > point 1
> > point 2
> > point 3
> > point 4
> > Convex Hull:
> > point 3
> > point 4
> > I want to read the 3 and 4, to make them correspond in my further
> > processing.
> > Thanks.
> > > Date: Thu, 24 Oct 2013 07:11:37 +0200
> > > From:
> > > To:
> > > On 10/24/2013 05:31 AM, Nuno Pessanha Santos wrote:
> > > > Hi,
> > > > I am starting to use CGAL, and maybe this is a stupid question
but I
> > > > need some help.
> > > > When you use the function "CGAL::convex_hull_3(points.begin(),
> > > > points.end(), Polyhedron_3 poly);" you obtain the polyhedron poly.
> > > > How can I read the obtained vertices or the points index that are
> > > > contained in the convex hull? I see so many examples but none
of them
> > > > could help me in my task.
> > > Is the following what you are looking for?
> > > Polyhedron_3 poly;
> > poly.points_end());
> > > Sebastien
> > > > Thanks
> > > You are currently subscribed to cgal-discuss.
> > > To unsubscribe or access the archives, go to
> > > https://sympa.inria.fr/sympa/info/cgal-discuss
