- To:
- Subject: Re: [cgal-discuss] mesh_domain_with_polyline_features_3
- Date: Mon, 28 Oct 2013 11:08:15 +0100
Le lundi 28 octobre 2013 10:38:47 Laurent Rineau a écrit :
> Le samedi 26 octobre 2013 11:34:20 Jack Lee a écrit :
> > Hello,
> > I am trying to generate a 3D mesh from multi-labelled images, with
> > polylines to preserve the corners.
> > Currently I'm trying it with a synthetically generated image, which is a
> > cylinder with a step increase in the diameter along its length. I've
> > tried the code below, which builds and executes without problem, but it
> > doesn't preserve the lines at all (see the screenshot). It's probably
> > (hopefully) some simple mistake, but I can't seem to find it. Could
> > somebody help please?
> I do not see any logical error in your code.
Actually, there was an error in the code:
> Mesh_criteria criteria(facet_angle=30, facet_size=4.5, facet_distance=5,
> cell_radius_edge_ratio=2, cell_size=size);
> Mesh_domain domain(image);
> domain.add_features(polylines.begin(), polylines.end());
For a domain with features, the criteria object must specify a 'edge_size' parameter, otherwise the code throw an error exception, in Debug, or does not mesh the polylines, in Release. You can set it to the same value as 'facet_size'.
Laurent Rineau, PhD
- [cgal-discuss] mesh_domain_with_polyline_features_3, Jack Lee, 10/26/2013
- Re: [cgal-discuss] mesh_domain_with_polyline_features_3, Laurent Rineau (CGAL/GeometryFactory), 10/28/2013
- RE: [cgal-discuss] mesh_domain_with_polyline_features_3, Lee, Jack, 10/28/2013
