cgal-discuss - Re: [cgal-discuss] About .locate function
  • To:
  • Subject: Re: [cgal-discuss] About .locate function
  • Date: Mon, 28 Oct 2013 10:44:49 +0100
On 10/28/2013 10:43 AM, Sebastien Loriot (GeometryFactory) wrote:
On 10/28/2013 10:40 AM, Laurent Rineau (CGAL/GeometryFactory) wrote:
Le mardi 22 octobre 2013 01:13:56 ffmm3 a écrit :
> If I want determine the relative position between the point(0.7,0.3)
and the
> triangle with vertices(-1,0)(1,0)(0,1) precisely, what should I do?
You would need a kernel with an exact arithmetic, like
CGAL::Exact_predicates_exact_construction_kernel
http://doc.cgal.org/latest/Kernel_23/classCGAL_1_1Exact__predicates__exact__constructions__kernel.html
... and you need to construct 0.7 as 7 / 10 and 0.3 as 3 / 10
I meant
typedef CGAL::Exact_predicates_exact_construction_kernel::FT FT;
FT(7) / FT(10) and FT(3) / FT(10)
Sebastien.
Laurent Rineau, PhD
