cgal-discuss - Re: [cgal-discuss] Nef_3 for 1000 triangles 5mins
  • To:
  • Subject: Re: [cgal-discuss] Nef_3 for 1000 triangles 5mins
  • Date: Thu, 07 Nov 2013 12:21:48 +0100
Le Wednesday 06 November 2013 22:27:14 ChaoM a écrit :
> Hi Laurent:
> I do not understand in your suggestion about the code optimization, I
> really do not know how to do it ? Can you point me out more detail?
> Thank you ~~
What were the compilation flags that were used to compile your program that
uses Nef polyhedron? There must be -O2/-O3 or /O2 or /O3 among them, so that
the compiler enables its code optimization. If you configured your program
with CMake, you must chose the "Release" build type.
Without any code optimization, your timings are about right, but with
optimization, I think that conversion from polyhedron to Nef polyhedron
should
be a lot faster.
Laurent Rineau, PhD
