- To: "" <>
- Subject: Re: [cgal-discuss] Nef polygon
- Date: Thu, 7 Nov 2013 08:11:52 -0500
In my experience, using the halfspace constructors took substantially longer.
Cody
On Nov 7, 2013, at 2:16 AM, ChaoM
wrote:
> Hello Sebastien:
> Thank you for the code about "Nef to solve 3D boolean Operation " several
> months ago. And I have used this method solving a lot of problems. But I
> currently meet a new problem which confused me for several days.The Problem
> is about the
> costing time.
> As you know, my goal is do the 3D boolean Operation between several models,
> these models consist of a lot of triangles. To finish my goal ,I use
> exquisite models, each model consists about 600 triangles, 300 vertex, so
> when I wanna to
> union 3 or more models together, the total triangles are about 2000.
> I do as your suggestion! Firstly, create polyhedron;Secondly ,convert
> polyhedrons to OFF files;Thirdly, the problem comes up, each OFF file
> contains 600 triangles and 300 vertex, when converting to Nef polyhedron, it
> costs about 2.5mins,
> when I need to do the conversion 3 times, it costs about 7.5mins, it's too
> long!
> Trying to improve efficiency of converting OFF to Nef, I replace the "Exact
> predicates exact constructions kernel" with "Gmpz kernel", but it cost me
> more long!
> Number of Model Total triangles Total vertex Time of Poly to
> OFF(seconds)
> OFF to Nef(seconds) Union(seconds) Nef toPoly(seconds)
> 2 1296 652 0.14
> 311.33 16.06 0.468
> 3 1944 978 0.156 424.72
> 35.42 1.047
> I research the mannul of CGAL, and read the concept of Nef polyhedron, find
> that there are two ways of constructing Nef polyhedron. One way is you
> suggest me , convert polyhedron to OFF, convert OFF to Nef. Another way is
> opetating halfspaces by unary opreation. So I wanna to know 2 problem:
> 1、 How to improve efficiency of converting OFF to Nef when there are 3 or
> more models needed to union?
> 2、 Whether I can use the second way to construct Nef?
> Since I know you are a exexpert on the 3D ,I hope you can point me out when
> you are not busy!
> Thank you very much!
> ChaoM
> View this message in context:
> http://cgal-discuss.949826.n4.nabble.com/Nef-polygon-tp4657453p4658375.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- Re: [cgal-discuss] Nef polygon, ChaoM, 11/07/2013
- Re: [cgal-discuss] Nef polygon, Cody Rose, 11/07/2013
- Re: [cgal-discuss] Nef polygon, ChaoM, 11/11/2013
