Re: [cgal-discuss] Using Point_set_2 with a Constrained_Delaunay_triangulation_2
- To:
- Subject: Re: [cgal-discuss] Using Point_set_2 with a Constrained_Delaunay_triangulation_2
- Date: Tue, 12 Nov 2013 19:13:12 +0100
Le Tuesday 12 November 2013 18:29:20
a écrit :
> Enough context, here are the actual questions :
> * is the constrained delaunay property too weak to satisfy the mathematical
> requirements of the query logics in Point_set_2 ? (so that their is no point
> hoping to plug the later on the former)
Yes, the properties of a constrained triangulation are too weak for the logic
of Point_set_2. Even if the code of Point_set_2 was adapted, there
performance
of queries would be guaranteed to be similar to what you get with a Delaunay
triangulation.
> * is there a way I could adapt / extend the library and contribute a way to
> answer queries on Constrained_Delaunay_2 instances
In the package "2D Conforming Triangulations and Meshes" of CGAL, there is a
section about conforming triangulations:
http://doc.cgal.org/latest/Mesh_2/index.html
Using that tool, you can transform a CDT
(Constrained_Delaunay_triangulation_2) to a CDT that has more vertices, and
is
mathematically a Delaunay triangulation. That might help you using the
Point_set_2 algorithms on your data.
Can we see a screenshot of the type of isolines you have? Are your typical
CDTs far from having the Delaunay property?
> * is there other accelerating query structures usable for constrained /not-
> really-Delaunay/ triangulations ?
You should tell us more about the type of queries you need.
Laurent Rineau, PhD
- [cgal-discuss] Using Point_set_2 with a Constrained_Delaunay_triangulation_2, anthony.truchet, 11/12/2013
- Re: [cgal-discuss] Using Point_set_2 with a Constrained_Delaunay_triangulation_2, Laurent Rineau (CGAL/GeometryFactory), 11/12/2013
