cgal-discuss - [cgal-discuss] Memory corruption with
  • To:
  • Subject: [cgal-discuss] Memory corruption with
  • Date: Tue, 12 Nov 2013 18:21:41 -0800
We recently started getting memory corruption errors during hilbert sorting when building regular triangulation on fedora 19 (gcc 4.82). This occurs with cgal 4.2 and 4.3. The .cpp, build command and outputs under normal running and valgrind are attached.
The disabling of the rounding check is to that things can run in valgrind, but the output is the same without it. Removing the -DCGAL_USE_GMP and -DCGAL_USE_MPFR doesn't make any difference.
Any suggestions? Thanks.
Attachment: build
Description: Binary data
Attachment: crash.output
Attachment: valgrind.output
#include <CGAL/Triangulation_vertex_base_3.h>
#include <CGAL/Alpha_shape_vertex_base_3.h>
#include <CGAL/Triangulation_cell_base_3.h>
#include <CGAL/Alpha_shape_cell_base_3.h>
//#include <CGAL/Triangulation_data_structure_3.h>
#include <CGAL/Weighted_alpha_shape_euclidean_traits_3.h>
#include <CGAL/Regular_triangulation_3.h>
#include <CGAL/version.h>
#include <CGAL/Fixed_alpha_shape_3.h>
#include <CGAL/Fixed_alpha_shape_vertex_base_3.h>
#include <CGAL/Fixed_alpha_shape_cell_base_3.h>
#include <CGAL/Alpha_shape_3.h>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef K::Point_3 Point;
typedef K::Segment_3 Segment;
typedef K::Vector_3 Vector;
typedef K::Line_3 Line;
typedef K::Triangle_3 Triangle3;
typedef CGAL::Regular_triangulation_euclidean_traits_3<K> Gt;
typedef CGAL::Fixed_alpha_shape_vertex_base_3<Gt> Vb;
typedef CGAL::Fixed_alpha_shape_cell_base_3<Gt> Fb;
typedef CGAL::Triangulation_data_structure_3<Vb, Fb> TDS;
typedef CGAL::Regular_triangulation_3<Gt, TDS> Triangulation;
typedef Gt::Point Wpoint;
int main(int, char * []) {
  std::cout << CGAL_VERSION_NR << std::endl;
  std::vector<Wpoint> pts;
  for (unsigned int i = 0; i < 1200; ++i) {
    pts.push_back(Wpoint(Point(i,i,i),
                         1));
  Triangulation T(pts.begin(), pts.end());
  return 0;
