- To:
- Subject: Re: [cgal-discuss] Memory corruption with
- Date: Tue, 12 Nov 2013 18:28:27 -0800
And then I caught up with reading cgal-develop and noticed the bug was just mentioned there. Never mind :-)
--Daniel
On Tue, Nov 12, 2013 at 6:21 PM, Daniel Russel <> wrote:
We recently started getting memory corruption errors during hilbert sorting when building regular triangulation on fedora 19 (gcc 4.82). This occurs with cgal 4.2 and 4.3. The .cpp, build command and outputs under normal running and valgrind are attached.The disabling of the rounding check is to that things can run in valgrind, but the output is the same without it. Removing the -DCGAL_USE_GMP and -DCGAL_USE_MPFR doesn't make any difference.
Any suggestions? Thanks.
- [cgal-discuss] Memory corruption with, Daniel Russel, 11/13/2013
- Re: [cgal-discuss] Memory corruption with, Daniel Russel, 11/13/2013
- Re: [cgal-discuss] Memory corruption with, Laurent Rineau (CGAL/GeometryFactory), 11/13/2013
