cgal-discuss - Re: [cgal-discuss] Voronoi adapter edge rejector
  • To:
  • Subject: Re: [cgal-discuss] Voronoi adapter edge rejector
  • Date: Wed, 13 Nov 2013 11:41:07 +0100
Following the documented API I would use
VD::Edge_rejector edge_rejector =
voronoi.adaptation_policy().edge_rejector_object();
if( !edge_rejector(delaunay, delaunayEdge) ) ...
Note that I haven't tested it.
Sebastien.
On 10/08/2013 11:41 AM, Martin Uhrin wrote:
Dear CGAL community,
I am using the following setup to generate a Voronoi diagram:
typedef CGAL::Delaunay_triangulation_2< K, Tds> Delaunay;
typedef CGAL::Delaunay_triangulation_adaptation_traits_2< Delaunay> AT;
typedef CGAL::Delaunay_triangulation_caching_degeneracy_removal_policy_2<
Delaunay> AP;
typedef CGAL::Voronoi_diagram_2< Delaunay, AT, AP> VD;
which successfully removes degenerate edges from the Voronoi. In part
for my code I iterate over all Delaunay edges and call
voronoi.dual(delaunayEdge)
but this causes assertions because some of the edges are rejected. Is
there a way to check if the Delaunay edge corresponds to a rejected
dual? Or with this setup am I only 'allowed' to go from Voronoi edges
to Delaunay edges and not the other way around?
At the moment I'm using:
if(!voronoi.edge_rejector()(delaunay, delaunayEdge))
but it seems quite clear from the source that edge_rejector(...) is
not API facing code.
Many thanks,
-Martin
